Installing on Linux
  • Python 2.7
  • pyGame
  • PyUSB (0.X or 1.X)
  • libusb
  • Python bindings for Qt4
Fedora
Ubuntu
Fix udev premissions on Linux
sudo groupadd plugdev
Installing on Windows
Windows XP/7
Only tested on Windows XP.
The following has to be downloaded/installed for the PC utilities to work on windows:
Installing on Mac OSX
projects/crazyflie/pc_utils/install.1358858161.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
