Installing on windows
Installing on Linux
  • Python 2.7
  • pyGame
  • PyUSB (0.X or 1.X)
  • libusb
  • Python bindings for Qt4
Fedora
Ubuntu
Fix udev premissions on Linux
sudo groupadd plugdev
Running the client
cd <cfclient folder>
python2 bin/cfclient
Windows XP
Windows Vista/7 32/64-bit
Installing on Mac OSX
Caveat: I don't know what I'm doing so this may or may not be correct information, but I figure some potentially wrong information is better than simply TODO. Also, this wiki makes for very hard formatting - just sayin'.
NOTE: For each of the following, make sure you grab the correct files for your specific version of OSX (i.e. Lion vs Mountain Lion)
  1. Open Terminal and see if Python is installed* (though it might be Apple modified), otherwise install Python
  2. Install Homebrew
    • type the following in the Terminal:
    • ruby -e "$(curl -fsSL https://raw.github.com/mxcl/homebrew/go)"
  3. Use Homebrew to install libusb
    • type in the Terminal:
      brew install libusb
    • (type
      brew doctor
      to see if everything is good. You may also need to install Command Line Tool)
  4. Install pyGame
    1. (alternatively, there maybe a Homebrew install method)
  5. Install pyQT4
    1. (though this is how far I got before getting stuck)
  6. Download CrazyFlie Client
    • start client by typing in Terminal:
    • python bin/cfclient
projects/crazyflie/pc_utils/install.1367797680.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
