The Crazyflie PC utilities are developed using Python 2.7. The Crazyflie library is used from the command line tools as well as a graphical user interface. On Windows an installer permits to run the client without having to install any dependencies, on linux the client can easily be run from source code. There is also a Raspberry Pi hack to run the client headless (without the GUI).
Installing on windows
Installing on Linux
  • Python 2.7
  • pyGame
  • PyUSB (0.X or 1.X)
  • libusb
  • Python bindings for Qt4
Fedora
Ubuntu
Fix udev premissions on Linux
su -
apt-get install sudo
sudo groupadd plugdev
Running the client
cd <cfclient folder>
python2 bin/cfclient
Windows XP
Windows Vista/7 32/64-bit
Installing on Mac OSX
  1. Open a terminal and install homebrew
    ruby -e "$(curl -fsSL https://raw.github.com/mxcl/homebrew/go)"
    You also need to install Command Line Tools for Xcode or Xcode if you don't already have them installed.
  2. With homebrew installed, install it's distribution of Python:
    brew install python
  3. Now make sure that the new python version is used for non-homebrew applications. To do this we need to prepend this installation to our PYTHONPATH:
    echo 'export PYTHONPATH=/usr/local/lib/python2.7/site-packages:$PYTHONPATH' >> ~/.bashrc
    source ~/.bashrc
  4. Install SDL for Python:
  5. Install PyQT:
    brew install pyqt
  6. Install Mercurial:
    brew install mercurial
  7. Now use pip to install pyGame:
  8. Install pyusb:
    pip install pyusb
python bin/cfclient
projects/crazyflie/pc_utils/install.1368362225.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
