Installing on windows
Installing on Linux
  • Python 2.7
  • pyGame
  • PyUSB (0.X or 1.X)
  • libusb
  • Python bindings for Qt4
Fedora
Ubuntu
Fix udev premissions on Linux
su -
apt-get install sudo
sudo groupadd plugdev
Running the client
cd <cfclient folder>
python2 bin/cfclient
Windows XP
Windows Vista/7 32/64-bit
Installing on Mac OSX
  1. Open a terminal and install homebrew
    ruby -e "$(curl -fsSL https://raw.github.com/mxcl/homebrew/go)"
    You also need to install Command Line Tools for Xcode or Xcode if you don't already have them installed.
  2. With homebrew installed, install it's distribution of Python:
    brew install python
  3. Now make sure that the new python version is used for non-homebrew applications. To do this we need to prepend this installation to our PYTHONPATH:
    echo 'export PYTHONPATH=/usr/local/lib/python2.7/site-packages:$PYTHONPATH' >> ~/.bashrc
    source ~/.bashrc
  4. Install SDL for Python:
  5. Install PyQT:
    brew install pyqt
  6. Install Mercurial:
    brew install mercurial
  7. Now use pip to install pyGame:
  8. Install pyusb:
    pip install pyusb
python bin/cfclient
projects/crazyflie/pc_utils/install.1368385002.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
