The firmware and PC client can be downloaded as binaries from the binary download page. To run the client after downloading it, decompress the file and run the cfclient in the bin folder, e.g.:
Otherwise consult the README or the instructions below for manual installation.
su - apt-get install sudo
cd crazyflie-pc-client sudo ./setup.sh
cfclient
brew install python
brew install pyqt
brew install libusb
brew install mercurial
pip install pyusb
python bin/cfclient
python2.7 bin/cfclient
