The firmware and PC client can be downloaded as binaries from the binary download page.
cd crazyflie-pc-client sudo sh setup.sh
cfclient
su - apt-get install sudo
brew install python
brew install pyqt
brew install libusb
brew install mercurial
pip install pyusb
python bin/cfclient
python2.7 bin/cfclient
