The firmware and PC client can be downloaded as binaries from the binary download page.
cd crazyflie-pc-client sudo sh setup.sh
cfclient
su - apt-get install sudo
Note - installing sudo is probably not required if using Raspbian Wheezy on a Raspberry Pi
sudo groupadd plugdev sudo usermod -a -G plugdev <username> (the default username for a Raspberry Pi is: Pi)
brew install python
brew install pyqt
brew install libusb
brew install mercurial
pip install pyusb
python bin/cfclient
python2.7 bin/cfclient
