To install the Crazyradio dongle follow the instruction Install crazyradio driver on Windows 7. The procedure is similar for windows XP. For Windows 8 you have to take care about the not signed driver.
The firmware and PC client can be downloaded as binaries from the binary download page.
cd crazyflie-pc-client sudo sh setup.sh
cfclient
The following steps make it possible to use the USB Radio with
