To install the Crazyradio dongle follow the instruction Install crazyradio driver on Windows 7. The procedure is similar for windows XP. For Windows 8 you have to take care about the not signed driver.
The firmware and PC client can be downloaded as binaries from the binary download page.
cd crazyflie-pc-client sudo sh setup.sh
cfclient
su - apt-get install sudo
Note - installing sudo is probably not required if using Raspbian Wheezy on a Raspberry Pi
sudo groupadd plugdev sudo usermod -a -G plugdev <username> (the default username for a Raspberry Pi is: Pi)
Create a file named /etc/udev/rules.d/99-crazyradio.rules
sudo touch /etc/udev/rules.d/99-crazyradio.rules
and open the nano editor to edit the newly created 99-crazyradio.rules file you created
sudo nano /etc/udev/rules.d/99-crazyradio.rules
The nano display will show there's no content in the file. Paste the following as a line in editor:
and hit Ctl-O to 'write out' (i.e. save) the new line into the file. Then Ctl-X to exit.
brew install python
brew install pyqt
brew install libusb
brew install mercurial
pip install pyusb
python bin/cfclient
port install libusb port install py-pyusb-devel port install py27-pyqt4 port install py27-game
python2.7 bin/cfclient
