To install the Crazyradio dongle follow the instruction Install crazyradio driver on Windows 7. The procedure is similar for windows XP. For Windows 8 you have to take care about the not signed driver.
The firmware and Python client can be downloaded as binaries from the binary download page.
cd crazyflie-clients-python sudo sh setup.sh
cfclient
su - apt-get install sudo
Note - installing sudo is probably not required if using Raspbian Wheezy on a Raspberry Pi
Check if there is a plugdev group:
groups
If there is not a plugdev group, then add a plugdev group:
sudo groupadd plugdev
Now execute the following command:
sudo usermod -a -G plugdev <username> (the default username for a Raspberry Pi is: Pi)
Create a file named /etc/udev/rules.d/99-crazyradio.rules
sudo touch /etc/udev/rules.d/99-crazyradio.rules
and open the nano editor to edit the newly created 99-crazyradio.rules file you created
sudo nano /etc/udev/rules.d/99-crazyradio.rules
The nano display will show there's no content in the file. Paste the following as a line in editor:
and hit Ctl-O to 'write out' (i.e. save) the new line into the file. Then Ctl-X to exit.
This procedure is required if you want to develop with the Crazyflie client on Windows. If you just want to run and fly the Crazyflie follow the instruction to install the client above.
brew install python
brew install pyqt
brew install libusb
brew install mercurial
pip install pyusb
python bin/cfclient
sudo port self update sudo port upgrade outdated
sudo port install -v python27 py27-pyqt4 py27-SDL2 py27-pyqtgraph py27-pyusb-devel
sudo port select --set python python27
python bin/cfclient
