Crazyflie Python client installation
Installing on windows
To install the Crazyradio dongle follow the instruction Install crazyradio driver on Windows 7. The procedure is similar for windows XP. For Windows 8 you have to take care about the not signed driver.
Installing on Linux
The firmware and Python client can be downloaded as binaries from the binary download page.
cd <cfclient folder>
python2 bin/cfclient
Automatic system-wide install using setup.sh
cd crazyflie-clients-python
sudo sh setup.sh
cfclient
Manual installation
Install dependencies
  • Python 3.4
  • pyGame
  • PyUSB (0.X or 1.X)
  • libusb
  • Python bindings for Qt4
Or to install them on Ubuntu (tested for 15.04):
sudo apt-get install python3 python3-pip python3-pyqt4 python3-zmq python3-pyqtgraph
sudo pip3 install pyusb==1.0.0b2
Fix udev permissions (Linux, Debian, Raspbian Wheezy, etc.)
su -
apt-get install sudo
Note - installing sudo is probably not required if using Raspbian Wheezy on a Raspberry Pi
Check if there is a plugdev group:
groups
If there is not a plugdev group, then add a plugdev group:
sudo groupadd plugdev
Now execute the following command:
sudo usermod -a -G plugdev <username> (the default username for a Raspberry Pi is: Pi)
Create a file named /etc/udev/rules.d/99-crazyradio.rules
sudo touch /etc/udev/rules.d/99-crazyradio.rules
and open the nano editor to edit the newly created 99-crazyradio.rules file you created
sudo nano /etc/udev/rules.d/99-crazyradio.rules
The nano display will show there's no content in the file. Paste the following as a line in editor:
and hit Ctl-O to 'write out' (i.e. save) the new line into the file. Then Ctl-X to exit.
This procedure is required if you want to develop with the Crazyflie client on Windows. If you just want to run and fly the Crazyflie follow the instruction to install the client above.
Windows XP
Windows Vista/7 32/64-bit
Installing on Mac OSX
Using homebrew
  1. Open a terminal and install homebrew
    ruby -e "$(curl -fsSL https://raw.github.com/mxcl/homebrew/go)"
    You also need to install Command Line Tools for Xcode or Xcode if you don't already have them installed.
  2. With homebrew installed, install it's distribution of Python:
    brew install python
  3. Now make sure that the new python version is used for non-homebrew applications. To do this we need to prepend this installation to our PYTHONPATH:
    echo 'export PYTHONPATH=/usr/local/lib/python2.7/site-packages:$PYTHONPATH' >> ~/.bashrc
    source ~/.bashrc
  4. Install SDL for Python:
  5. Install PyQT:
    brew install pyqt
  6. Install libusb:
    brew install libusb
  7. Install Mercurial:
    brew install mercurial
  8. Now use pip to install pyGame:
  9. Install pyusb:
    pip install pyusb
python bin/cfclient
Using MacPorts
  1. If you do not have MacPorts installed yet please follow the installation guide.
  2. If you just installed MacPorts you can skip this step, otherwise make sure you update before you continue:
    sudo port self update
    sudo port upgrade outdated
  3. Then go ahead and install the dependencies needed for the crazyflie client, this will also bring in lots of other dependencies, especially Qt will take a while:
    sudo port install -v python27 py27-pyqt4 py27-SDL2 py27-pyqtgraph py27-pyusb-devel
  4. To make it easier to run MacPorts binaries add /opt/local/bin to your PATH variable, The MacPorts installer should take care of that but take a look at ~/.profile to make sure. If you have any issues it could be due to the libraries not getting picked up correctly, fix that by setting DYLD_LIBRARY_PATH to /opt/local/lib in ~/.profile:
    export DYLD_LIBRARY_PATH=/opt/local/lib
  5. To ensure we use the MacPorts Python installation, select it using the 'port' command:
    sudo port select --set python python27
  6. No you're good to go! Download and extract the client, change into the newly extracted directory, and then start the client by running the following in a terminal:
    python bin/cfclient
projects/crazyflie/pc_utils/install.1441787592.txt.gz · Last modified: 2015-09-09 10:33 by macke
