Below are the two examples described in the video <insert link here> that shows the parameter and logging framework.
# Callback called when the connection is established to the Crazyflie def connected(linkURI): gyroconf = LogConfig("Gyro", 10) gyroconf.addVariable(LogVariable("gyro.x", "float")) gyroconf.addVariable(LogVariable("gyro.y", "float")) gyroconf.addVariable(LogVariable("gyro.z", "float")) # crazyflie is an instance of the Crazyflie class that has been instantiated and connected gyrolog = crazyflie.log.newLogPacket(gyroconf) if (gyrolog != None): gyrolog.dataReceived.addCallback(self.gyroData) gyrolog.startLogging() else: print "gyro.x/y/z not found in log TOC" def gyroData(data): print "Gyrodata: x=%.2f, y=%.2f, z=%.2f" % (data["gyro.x"], data["gyro.y"], data["gyro.z"])
