<insert more text here>
Below are the two examples described in the video <insert link here> that shows the parameter and logging framework. They have been re-written to fit outside the QT context so they do not match the video 1:1 but they show the same concept.
Remember that if you use the callbacks for parameters and logging together with QT and the callbacks manipulate objects in the UI then they have to be wrapped using signals. Otherwise you will en up with timing issues that will (at some point) crash the application since UI objects should only be updated but the same thread that draws the objects.
