If you are interested in more details look in the PyDoc in the code or at the communication protocol logging or parameters.
cflib.crtp.initDrivers() available = cflib.crtp.scanInterfaces() for a in available: print "Interface with URI [%s] found and name/comment [%s]" % (a[0], a[1])
crazyflie = Crazyflie() crazyflie.openLink(radio://0/10/250K) # Do stuff crazyflie.closeLink()
Currently all the communication is either parameters, logging or control commands. The special case of control commands is minimize latency since it's a faster way than using parameters.
roll = 0.0 pitch = 0.0 yawrate = 0 thrust = 0 crazyflie.commander.sendControlSetpoint(roll, pitch, yawrate, thrust)
Remember that if you use the callbacks for parameters and logging together with QT and the callbacks manipulate objects in the UI then they have to be wrapped using signals. Otherwise you will en up with timing issues that will (at some point) crash the application since UI objects should only be updated but the same thread that draws the objects.
