cflib.crtp.initDrivers() available = cflib.crtp.scanInterfaces() for a in available: print "Interface with URI [%s] found and name/comment [%s]" % (a[0], a[1])
crazyflie = Crazyflie() crazyflie.openLink("radio://0/10/250K") # Do stuff crazyflie.closeLink()
Currently all the communication is either parameters, logging or control commands. The special case of control commands is minimize latency since it's a faster way than using parameters.
roll = 0.0 pitch = 0.0 yawrate = 0 thrust = 0 crazyflie.commander.sendControlSetpoint(roll, pitch, yawrate, thrust)
