Currently all the communication is either parameters, logging or control commands. The special case of control commands is minimize latency since it's a faster way than using parameters.
roll = 0.0 pitch = 0.0 yawrate = 0 thrust = 0 crazyflie.commander.sendControlSetpoint(roll, pitch, yawrate, thrust)
