Currently all the communication is either parameters, logging or control commands. The special case of control commands is to minimize latency since it's a faster way than using parameters.
Thrust is an integer value ranging from 10001 (next to no power) to 60000 (full power). Sending a command makes it apply for 2 seconds, after which the firmware will cut out the power. Depending on where the Crazyflie is, this can be a Bad Thing! With this in mind, you need to try and maintain a thrust level, with a tick being sent at least once every 2 seconds. Ideally you should be sending one tick every 0.01 seconds, for 100 commands a second. This has a nice added benefit of allowing for very precise control.
