projects:crazyflie:pc_utils:pylib
The Crazyflie Python API
Structure of the library
  • connectionInitiated - Called when a request has been made to the library to establish a connection
  • connectSetupFinished - Called when the connection has been established and the log/param TOC has been downloaded
  • disconnected - Called when the connection has been closed (both when requested and not requested to close)
  • connectionLost - Called when the connection has been closed (without being requested to be closed)
  • connectionFailed - Called if the connection fails when it is being established (between the request and connection setup finished)
  • linkQuality - Called periodically to report link status. This is done at the discretion of the link drivers
    crazyflie = Crazyflie()
    crazyflie.linkQuality.addCallback(linkQualityCallback)
Uniform Resource Identifier (URI)
  • radio://0/10/250K (Radio interface, USB dongle number 0, radio channel 10 and radio speed 250 Kbit/s)
  • debug://0/1 (Debug interface, id 0, channel 1)
Variable and parameter names
  • stabalizer.roll
  • system.battery
Finding a Crazyflie and connecting
    cflib.crtp.init_drivers()
    available = cflib.crtp.scan_interfaces()
    for i in available:
        print "Interface with URI [%s] found and name/comment [%s]" % (i[0], i[1])
    crazyflie.open_link("radio://0/10/250K")
    # Do stuff
    crazyflie.close_link()
Sending control commands
Currently all the communication is either parameters, logging or control commands. The special case of control commands is to minimize latency since it's a faster way than using parameters.
    roll    = 0.0
    pitch   = 0.0
    yawrate = 0
    thrust  = 0
    crazyflie.commander.send_setpoint(roll, pitch, yawrate, thrust)
Thrust is an integer value ranging from 10001 (next to no power) to 60000 (full power). Sending a command makes it apply for 2 seconds, after which the firmware will cut out the power. Depending on where the Crazyflie is, this can be a Bad Thing! With this in mind, you need to try and maintain a thrust level, with a tick being sent at least once every 2 seconds. Ideally you should be sending one tick every 0.01 seconds, for 100 commands a second. This has a nice added benefit of allowing for very precise control.
Parameters
  • The parameter is not changed by the Crazyflie but by the client
  • The parameter is not read periodically
    parameterName = "group.name"
    parameterValue = 3
    crazyflie.param.setParamValue(parameterName, parameterValue)
    crazyflie.param.addParamUpdateCallback("group.name", paramUpdateCallback)
    def paramUpdateCallback(name, value):
        print "%s has value %d" % (name, value)
Logging
  • The variable is changed by the Crazyflie and not by the client
  • The variable is updated at high rate and you want to read the value periodically
    periodInMilliSeconds = 10
    logconf = LogConfig("Logging", periodInMilliSeconds)
    logconf.addVariable(LogVariable("group1.name1", "float"))
    logconf.addVariable(LogVariable("group1.name2", "uint8_t"))
    logconf.addVariable(LogVariable("group2.name1", "int16_t"))
  • float
  • uint8_t and int8_t
  • uint16_t and int16_t
  • uint32_t and int32_t
  • FP16 (this is a fixed point version of floating point)
    # Callback called when the connection is established to the Crazyflie
    def connected(linkURI):
        logpacket = crazyflie.log.newLogPacket(logconf)
        if (logpacket != None):
            logpacket.dataReceived.addCallback(dataCallback)
            logpacket.startLogging()
        else:
            print "One or more of the variables in the configuration was not found in log TOC. No logging will be possible."
    def dataCallback(data):
        # Print all the keys and values for them
        for k in data.keys():
            print "Key: %s=%s" % (k, str(data[k]))
Logging and parameter examples
Adding a parameter
In this example we will add a parameter that will be used to “freeze” the LED update function. This isn't very useful but it shows how to use parameters :-)
#include "param.h"
bool ledFreeze = false;
PARAM_GROUP_START(led)
PARAM_ADD(PARAM_UINT8, freeze, &ledFreeze)
PARAM_GROUP_STOP(led)
# crazyflie is an instance of the Crazyflie class that has been instantiated and connected
    crazyflie.param.setParamValue("led.freeze", True)
  • When the Crazyflie has connected values for all the parameters in the TOC are fetched
  • When the client changes a value for a parameter the new value will be sent back from the Crazyflie
    crazyflie.param.addParamUpdateCallback("led.freeze", paramUpdateCallback)
        print "%s has value %s" % (name, value) # This will in our example print: led.freeze has value True
Adding loggable variables
#include "log.h"
// The raw gyro values are stored in the gyro struct
LOG_GROUP_START(gyro)
LOG_ADD(LOG_FLOAT, x, &gyro.x)
LOG_ADD(LOG_FLOAT, y, &gyro.y)
LOG_ADD(LOG_FLOAT, z, &gyro.z)
LOG_GROUP_STOP(gyro)
        gyroconf = LogConfig("Gyro", 10)
        gyroconf.addVariable(LogVariable("gyro.x", "float"))
        gyroconf.addVariable(LogVariable("gyro.y", "float"))
        gyroconf.addVariable(LogVariable("gyro.z", "float"))
        gyrolog = crazyflie.log.newLogPacket(gyroconf)
        if (gyrolog != None):
            gyrolog.dataReceived.addCallback(gyroData)
            gyrolog.startLogging()
        else:
            print "gyro.x/y/z not found in log TOC"
    def gyroData(data):
        print "Gyrodata: x=%.2f, y=%.2f, z=%.2f" % (data["gyro.x"], data["gyro.y"], data["gyro.z"])
Simple code example
As a starter guide, this application connects to the Crazyflie, turns on the motors and then asks the user to set the thrust level.
import time
from threading import Thread
import cflib.crtp
class Main:
    # Initial values, you can use these to set trim etc.
    roll = 0.0
    pitch = 0.0
    yawrate = 0
    thrust = 10001
    def __init__(self):
        self.crazyflie = Crazyflie()
        # You may need to update this value if your Crazyradio uses a different frequency.
        self.crazyflie.open_link("radio://0/10/250K")
        self.crazyflie.connectSetupFinished.add_callback(self.connectSetupFinished)
    def connectSetupFinished(self, linkURI):
        # Keep the commands alive so the firmware kill-switch doesn't kick in.
        Thread(target=self.pulse_command).start()
        while 1:
            self.thrust = int(raw_input("Set thrust (10001-60000):"))
            if self.thrust == 0:
                self.crazyflie.close_link()
                break
            elif self.thrust <= 10000:
                self.thrust = 10001
            elif self.thrust > 60000:
                self.thrust = 60000
    def pulse_command(self):
        self.crazyflie.commander.send_setpoint(self.roll, self.pitch, self.yawrate, self.thrust)
        time.sleep(0.1)
        # ..and go again!
        self.pulse_command()
Main()
projects/crazyflie/pc_utils/pylib.1367788681.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
