Currently all the communication is either parameters, logging or control commands. The special case of control commands is to minimize latency since it's a faster way than using parameters.
Thrust is an integer value ranging from 10001 (next to no power) to 60000 (full power). Sending a command makes it apply for 2 seconds, after which the firmware will cut out the power. Depending on where the Crazyflie is, this can be a Bad Thing! With this in mind, you need to try and maintain a thrust level, with a tick being sent at least once every 2 seconds. Ideally you should be sending one tick every 0.01 seconds, for 100 commands a second. This has a nice added benefit of allowing for very precise control.
As a starter guide, this application connects to the Crazyflie, turns on the motors and then asks the user to set the thrust level.
import time from threading import Thread import cflib.crtp from cflib.crazyflie import Crazyflie class Main: # Initial values, you can use these to set trim etc. roll = 0.0 pitch = 0.0 yawrate = 0 thrust = 10001 def __init__(self): self.crazyflie = Crazyflie() cflib.crtp.init_drivers() # You may need to update this value if your Crazyradio uses a different frequency. self.crazyflie.open_link("radio://0/10/250K") self.crazyflie.connectSetupFinished.add_callback(self.connectSetupFinished) def connectSetupFinished(self, linkURI): # Keep the commands alive so the firmware kill-switch doesn't kick in. Thread(target=self.pulse_command).start() while 1: self.thrust = int(raw_input("Set thrust (10001-60000):")) if self.thrust == 0: self.crazyflie.close_link() break elif self.thrust <= 10000: self.thrust = 10001 elif self.thrust > 60000: self.thrust = 60000 def pulse_command(self): self.crazyflie.commander.send_setpoint(self.roll, self.pitch, self.yawrate, self.thrust) time.sleep(0.1) # ..and go again! self.pulse_command() Main()
