Currently all the communication is either parameters, logging or control commands. The special case of control commands is to minimize latency since it's a faster way than using parameters.
Thrust is an integer value ranging from 10001 (next to no power) to 60000 (full power). Sending a command makes it apply for 0.5 seconds, after which the firmware will cut out the power. Depending on where the Crazyflie is, this can be a Bad Thing! With this in mind, you need to try and maintain a thrust level, with a tick being sent at least once every 2 seconds. Ideally you should be sending one tick every 0.01 seconds, for 100 commands a second. This has a nice added benefit of allowing for very precise control.
# Callback called when the connection is established to the Crazyflie def connected(linkURI): logpacket = crazyflie.log.newLogPacket(logconf) if (logpacket != None): logpacket.data_received.addCallback(dataCallback) logpacket.startLogging() else: print "One or more of the variables in the configuration was not found in log TOC. No logging will be possible." def dataCallback(data): # Print all the keys and values for them for k in data.keys(): print "Key: %s=%s" % (k, str(data[k]))
# Callback called when the connection is established to the Crazyflie def connected(linkURI): gyroconf = LogConfig("Gyro", 10) gyroconf.addVariable(LogVariable("gyro.x", "float")) gyroconf.addVariable(LogVariable("gyro.y", "float")) gyroconf.addVariable(LogVariable("gyro.z", "float")) # crazyflie is an instance of the Crazyflie class that has been instantiated and connected gyrolog = crazyflie.log.newLogPacket(gyroconf) if (gyrolog != None): gyrolog.data_received.addCallback(gyroData) gyrolog.startLogging() else: print "gyro.x/y/z not found in log TOC" def gyroData(data): print "Gyrodata: x=%.2f, y=%.2f, z=%.2f" % (data["gyro.x"], data["gyro.y"], data["gyro.z"])
This example requires Crazyflie firmware newer then this commit where the accelerometer variables has been exposed by the firmware. (It is not included in the 2013.4 release)
import logging import cflib.crtp from cfclient.utils.logconfigreader import LogConfig from cfclient.utils.logconfigreader import LogVariable from cflib.crazyflie import Crazyflie logging.basicConfig(level=logging.DEBUG) class Main: """ Class is required so that methods can access the object fields. """ def __init__(self): """ Connect to Crazyflie, initialize drivers and set up callback. The callback takes care of logging the accelerometer values. """ self.crazyflie = Crazyflie() cflib.crtp.init_drivers() self.crazyflie.connectSetupFinished.add_callback( self.connectSetupFinished) self.crazyflie.open_link("radio://0/10/250K") def connectSetupFinished(self, linkURI): """ Configure the logger to log accelerometer values and start recording. The logging variables are added one after another to the logging configuration. Then the configuration is used to create a log packet which is cached on the Crazyflie. If the log packet is None, the program exits. Otherwise the logging packet receives a callback when it receives data, which prints the data from the logging packet's data dictionary as logging info. """ # Set accelerometer logging config accel_log_conf = LogConfig("Accel", 10) accel_log_conf.addVariable(LogVariable("acc.x", "float")) accel_log_conf.addVariable(LogVariable("acc.y", "float")) accel_log_conf.addVariable(LogVariable("acc.z", "float")) # Now that the connection is established, start logging self.accel_log = self.crazyflie.log.create_log_packet(accel_log_conf) if self.accel_log is not None: self.accel_log.data_received.add_callback(self.log_accel_data) self.accel_log.start() else: print("acc.x/y/z not found in log TOC") def log_accel_data(self, data): logging.info("Accelerometer: x=%.2f, y=%.2f, z=%.2f" % (data["acc.x"], data["acc.y"], data["acc.z"])) Main()
As a starter guide, this application connects to the Crazyflie, turns on the motors, ramps up/down the rpm and then quits.
import time, sys from threading import Thread sys.path.append("lib") import cflib from cflib.crazyflie import Crazyflie class Main: def __init__(self): self.crazyflie = Crazyflie() cflib.crtp.init_drivers() # You may need to update this value if your Crazyradio uses a different frequency. self.crazyflie.open_link("radio://0/10/250K") # Set up the callback when connected self.crazyflie.connectSetupFinished.add_callback(self.connectSetupFinished) def connectSetupFinished(self, linkURI): # Start a separate thread to do the motor test. # Do not hijack the calling thread! Thread(target=self.pulse_command).start() def pulse_command(self): thrust_mult = 1 thrust_step = 500 thrust = 20000 pitch = 0 roll = 0 yawrate = 0 while thrust >= 20000: self.crazyflie.commander.send_setpoint(roll, pitch, yawrate, thrust) time.sleep(0.1) if (thrust >= 25000): thrust_mult = -1 thrust = thrust + (thrust_step * thrust_mult) self.crazyflie.commander.send_setpoint(0,0,0,0) # Make sure that the last packet leaves before the link is closed # since the message queue is not flushed before closing time.sleep(0.1) self.crazyflie.close_link() Main()
