The library is asynchronous and based on callbacks for events. Functions like open_link will return immediately, and the callback connected will be called when the link is opened. The library doesn't contain any threads or locks that will keep the application running, it's up to the application that is using the library to do this.
The library supports setting up logging configurations that are used for logging variables from the firmware. Each log configuration contains a number of variables that should be logged as well as a time period (in ms) of how often the data should be sent back to the host. Once the log configuration is added to the firmware the firmware will automatically send back the data at every period. These configurations are used in the following way:
There's a few limitations that needs to be taken into account:
The library supports reading and writing parameters at run-time to the firmware. This is intended to be used for data that is not continuously being changed by the firmware, like setting regulation parameters and reading out if the power-on self-tests passed. Parameters should only change in the firmware when being set from the host or during start-up. The library doesn't continuously update the parameter values, this should only be done once after connecting. After each write to a parameter the firmware will send back the updated value and this will be forwarded to callbacks registered for reading this parameter. The parameters should be used in the following way:
All names of parameters and log variables use the same structure: group.name
The group should be used to bundle together logical groups, like everything that has to do with the stabilizer should be in the group stabilizer.
There's a limit of 28 chars in total and here are some examples:
All callbacks are handled using the Caller class that contains the following methods:
def add_callback(cb) """ Register cb as a new callback. Will not register duplicates. """ def remove_callback(cb): """ Un-register cb from the callbacks """ def call(*args): """ Call the callbacks registered with the arguments args """
Operations on the link and connection will return directly and will call the following callbacks when events occur:
# Called on disconnect, no matter the reason disconnected = Caller() # Called on unintentional disconnect only connection_lost = Caller() # Called when the first packet in a new link is received link_established = Caller() # Called when the user requests a connection connection_requested = Caller() # Called when the link is established and the TOCs (that are not cached) # have been downloaded connected = Caller() # Called if establishing of the link fails (i.e times out) connection_failed = Caller() # Called for every packet received packet_received = Caller() # Called for every packet sent packet_sent = Caller() # Called when the link driver updates the link quality measurement link_quality_updated = Caller()
crazyflie = Crazyflie() crazyflie.connected.add_callback(crazyflie_connected)
Currently all the communication is either parameters, logging or control commands. The special case of control commands is to minimize latency since it's a faster way than using parameters.
Thrust is an integer value ranging from 10001 (next to no power) to 60000 (full power). Sending a command makes it apply for 0.5 seconds, after which the firmware will cut out the power. Depending on where the Crazyflie is, this can be a Bad Thing! With this in mind, you need to try and maintain a thrust level, with a tick being sent at least once every 2 seconds. Ideally you should be sending one tick every 0.01 seconds, for 100 commands a second. This has a nice added benefit of allowing for very precise control.
param_name = "group.name" param_value = 3 crazyflie.param.set_value(param_name, param_value)
crazyflie.param.add_update_callback(group="group", name="name", param_updated_callback) def param_updated_callback(name, value): print "%s has value %d" % (name, value)
logconf = LogConfig(name="Logging", period_in_ms=100) logconf.add_variable("group1.name1", "float") logconf.add_variable("group1.name2", "uint8_t") logconf.add_variable("group2.name1", "int16_t")
# Callback called when the connection is established to the Crazyflie def connected(link_uri): crazyflie.log.add_coonfig(logconf) if logconf.valid: logconf.data_received_cb.add_callback(data_received_callback) logconf.error_cb.add_callback(logging_error) logconf.start() else: print "One or more of the variables in the configuration was not found in log TOC. No logging will be possible." def data_received_callback(timestamp, data, logconf): print "[%d][%s]: %s" % (timestamp, logconf.name, data) def logging_error(logconf, msg)
# Callback called when the connection is established to the Crazyflie def connected(linkURI): gyroconf = LogConfig("Gyro", 10) gyroconf.addVariable(LogVariable("gyro.x", "float")) gyroconf.addVariable(LogVariable("gyro.y", "float")) gyroconf.addVariable(LogVariable("gyro.z", "float")) # crazyflie is an instance of the Crazyflie class that has been instantiated and connected gyrolog = crazyflie.log.newLogPacket(gyroconf) if (gyrolog != None): gyrolog.data_received.addCallback(gyroData) gyrolog.startLogging() else: print "gyro.x/y/z not found in log TOC" def gyroData(data): print "Gyrodata: x=%.2f, y=%.2f, z=%.2f" % (data["gyro.x"], data["gyro.y"], data["gyro.z"])
This example requires Crazyflie firmware newer then this commit where the accelerometer variables has been exposed by the firmware. (It is not included in the 2013.4 release)
import logging import cflib.crtp from cfclient.utils.logconfigreader import LogConfig from cfclient.utils.logconfigreader import LogVariable from cflib.crazyflie import Crazyflie logging.basicConfig(level=logging.DEBUG) class Main: """ Class is required so that methods can access the object fields. """ def __init__(self): """ Connect to Crazyflie, initialize drivers and set up callback. The callback takes care of logging the accelerometer values. """ self.crazyflie = Crazyflie() cflib.crtp.init_drivers() self.crazyflie.connectSetupFinished.add_callback( self.connectSetupFinished) self.crazyflie.open_link("radio://0/10/250K") def connectSetupFinished(self, linkURI): """ Configure the logger to log accelerometer values and start recording. The logging variables are added one after another to the logging configuration. Then the configuration is used to create a log packet which is cached on the Crazyflie. If the log packet is None, the program exits. Otherwise the logging packet receives a callback when it receives data, which prints the data from the logging packet's data dictionary as logging info. """ # Set accelerometer logging config accel_log_conf = LogConfig("Accel", 10) accel_log_conf.addVariable(LogVariable("acc.x", "float")) accel_log_conf.addVariable(LogVariable("acc.y", "float")) accel_log_conf.addVariable(LogVariable("acc.z", "float")) # Now that the connection is established, start logging self.accel_log = self.crazyflie.log.create_log_packet(accel_log_conf) if self.accel_log is not None: self.accel_log.data_received.add_callback(self.log_accel_data) self.accel_log.start() else: print("acc.x/y/z not found in log TOC") def log_accel_data(self, data): logging.info("Accelerometer: x=%.2f, y=%.2f, z=%.2f" % (data["acc.x"], data["acc.y"], data["acc.z"])) Main()
As a starter guide, this application connects to the Crazyflie, turns on the motors, ramps up/down the rpm and then quits.
import time, sys from threading import Thread sys.path.append("lib") import cflib from cflib.crazyflie import Crazyflie class Main: def __init__(self): self.crazyflie = Crazyflie() cflib.crtp.init_drivers() # You may need to update this value if your Crazyradio uses a different frequency. self.crazyflie.open_link("radio://0/10/250K") # Set up the callback when connected self.crazyflie.connectSetupFinished.add_callback(self.connectSetupFinished) def connectSetupFinished(self, linkURI): # Start a separate thread to do the motor test. # Do not hijack the calling thread! Thread(target=self.pulse_command).start() def pulse_command(self): thrust_mult = 1 thrust_step = 500 thrust = 20000 pitch = 0 roll = 0 yawrate = 0 while thrust >= 20000: self.crazyflie.commander.send_setpoint(roll, pitch, yawrate, thrust) time.sleep(0.1) if (thrust >= 25000): thrust_mult = -1 thrust = thrust + (thrust_step * thrust_mult) self.crazyflie.commander.send_setpoint(0,0,0,0) # Make sure that the last packet leaves before the link is closed # since the message queue is not flushed before closing time.sleep(0.1) self.crazyflie.close_link() Main()
