projects:crazyflie:pc_utils:raspberrypi
Modifying the Raspian Wheezy image
Note Since version 2015.3 you can setup your own SDCard in one command.
  • An SD-card that's at least 4GB
  • An ethernet cable to connect the Pi to your network
  • A power cord to power it
  • An SD-card reader for a computer
Info All modern Linux distribution now have a kernel driver for the x-box gamepad. Thus it is unlikely the xboxdrv user-space driver is needed.
Lets install everything that we might need fro running the Crazyradio, controllers and the headless client.
sudo apt-get -y install python-usb xboxdrv
sudo touch /etc/udev/rules.d/99-crazyflie.rules
sudo nano /etc/udev/rules.d/99-crazyflie.rules
In order for the Xbox 360 wireless controller to work the xboxdrv utility has to be installed and launched when the controller is connected. So add a new udev rule for this.
sudo nano /etc/udev/rules.d/99-xboxdrv.rules
Put the following into the text file:
sudo mkdir /root/bin/
sudo touch /root/bin/cfheadless
sudo chmod +x /root/bin/cfheadless
sudo nano /root/bin/cfheadless
And add the following text:
#!/bin/sh
if test "$ACTION" = "add"
then
        /usr/bin/sudo -u bitcraze /home/bitcraze/start_cfheadless &
        echo $! > /tmp/cfheadless.pid
else
        killall -9 cfheadless
        then
                PID=`cat /tmp/cfheadless.pid`
                kill -9 $PID
        fi
fi
sudo touch /root/bin/xbox360
sudo chmod +x /root/bin/xbox360
sudo nano /root/bin/xbox360
#!/bin/sh
then
        /usr/bin/xboxdrv &
else
        killall -9 xboxdrv
fi
Go to the pi users home directory and clone the PC client and Crazyradio firmware projects.
cd
mkdir projects
cd projects
git clone https://github.com/bitcraze/crazyflie-clients-python.git
Create the script that will execute when the Crazyradio is inserted. This will launch the cfheadless client.
cd
touch start_cfheadless
chmod +x start_cfheadless
nano start_cfheadless
Insert the following text into the file:
/home/pi/projects/crazyflie-clients-python/bin/cfheadless -u `cat /home/pi/link.conf` -i `cat /home/pi/controller.conf` > /tmp/cfheadless.log 2>&1
Now the last part, the configuration. The script above will launch the cfheadless client with the controller and link configuration that is written in the two files 'controller.conf' and 'link.conf'. This configuration is written using the following commands:
echo PS3_Mode_1 > /home/pi/controller.conf
echo radio://0/10/250K > /home/pi/link.conf
If you are using another controller configuration or another link, just use the same commands as above but replace it with your own settings.
That's it! Now you can connect the controller, start the Crazyflie and insert the Crazyradio and you are ready to fly.
update_on_pi_release
projects/crazyflie/pc_utils/raspberrypi.txt · Last modified: 2021-06-24 14:47 by kimberly
