projects:crazyradio:programming
Radio programming
The Radio dongle can be programmed either via USB bootloader or via SPI. The USB bootloader does not require any hardware but is not currently (as of 2012-09) full-proof (if the flash procedure does not complete well the dongle will have to be reprogrammed via spi). It is recommended to program only released firmware via USB.
USB bootloader (command line instructions)
> cd pc_util/crazyradio/
> python launchBootloader.py
Launching bootloader ..
Bootloader launched.
> python nrfbootload.py flash /path/to/cradio.bin
projects/crazyradio/programming.1367935535.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
