The Radio dongle can be programmed either via USB bootloader or via <acronym title=“Serial Peripheral Interface Bus”>SPI</acronym>. The USB bootloader does not require any hardware but is not currently (as of 2012-09) full-proof (if the flash procedure does not complete well the dongle will have to be reprogrammed via spi). It is recommended to program only released firmware via USB.
> cd pc_util/crazyradio/ > python launchBootloader.py Launching bootloader .. Bootloader launched. >
> python nrfbootload.py flash /path/to/cradio.bin
