projects:virtualmachine:index
Bitcraze Virtual Machine
In order to easily get going with the development of Bitcraze projects we have pre-configured a virtual machine that can be imported into WM Player or Oracle VirtualBox.
The username/password for the virtual machine is: bitcraze/crazyflie
If you have any comments or suggestions drop by the forum thread and discuss them there.
Download
Currently the virtual machine applicance is only available via torrent using this link.
What's in the virtual machine?
The machine includes:
  • Pre-cloned version of the public bicraze projects from bitbucket (software and firmware)
  • All development tools to compile Crazyflie firmware and bootloader, Crazyradio firmware
  • All python lib to run the Crazyflie PC client
  • Eclipse pre-configured to develop on Crazyflie firmware and PC-Client + QtDesigner to edit the GUI files
  • A readme that explains how to start
The next version will also include:
  • Hardware dev tools
  • Tool and configuration to debug the Crazyflie (currently only tools to compile are present)
  • Reduce the image size (it is currently 2.2GB which I find quite big, I should be able to cut a lot of useless stuff by starting from a minimal install)
  • More documentation in the VM and on the Wiki
How do I pull the latest changes from the repository on Bitbucket?
Pulling the latest changes of the firmware and client can be done using the following commands:
hg pull && hg update
How do I build the firmware with the latest changes from the repository on Bitbucket?
Running the following commands will pull the latest changes from the repository on Bitbucket and build the firmware which can be flashed with the wireless bootloader. For updating the Crazyflie use the resulting cflie.bin.
make CLOAD=1 DEBUG=0
projects/virtualmachine/index.1367479183.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
