OS : Xubuntu 13.04 HDD : 10 GB (dynamically sized) RAM : 1 GB User: bitcraze Pass: crazyflie
cd ~/projects/crazyflie-firmware hg pull && hg update -C 2013.4 cd ~/projects/crazyflie-pc-client hg pull && hg update -C 2013.4.2
cd ~/projects/crazyflie-firmware make CLOAD=1 DEBUG=0
