projects:virtualmachine:index
Bitcraze Virtual Machine
Download
  • Bitcraze VM 0.2 via torrent
  • Bitcraze VM 0.3 via torrent
  • Bitcraze VM 0.3 from here (hosted at MEGA so it's limited to 6 downloads at a time)
VM info
OS  : Xubuntu 13.04
HDD : 10 GB (dynamically sized)
RAM : 1 GB
User: bitcraze
Pass: crazyflie
Configuration
Installed software
  • Mercurial
  • TortoiseHG
  • pyusb, pygame and pyqt
  • Qt4 and QtDesigner
  • KiCad
  • gedit
  • SDCC 3.2
Projects
  • crazyflie-firmware
  • crazyflie-bootloader
  • crazyflie-pc-client
  • crazyradio-firmware
  • crazyradio-electronics
Development
  • Update and build the latest versions of the Crazyflie/Crazyradio firmware
  • Debug the Crazyflie firmware via JTAG (pre-configured for BusBlaster)
  • View and modify the Crazyradio electronics design
  • Develop for Crazyflie PC client with QtDesigner for the UI
HOW-TOs
Update all the projects
Run the Crazyflie PC client
Build the Crazyflie firmware
make CLOAD=1 DEBUG=0
projects/virtualmachine/index.1371559819.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
