projects:virtualmachine:index
Bitcraze Virtual Machine
Download
  • Bitcraze VM 0.2 via torrent
  • Bitcraze VM 0.3 via torrent
  • Bitcraze VM 0.3 from here (hosted at MEGA so it's limited to 6 downloads at a time)
VM info
OS  : Xubuntu 13.04
HDD : ~8.8 GB (dynamically sized)
RAM : 1 GB
User: bitcraze
Pass: crazyflie
Configuration
NOTE: The USB filters in the 0.3 version of the VM specify a serial number for the radio dongle. This means the pre-configured filter cannot be used as is. Create your own filter by plugging in the radio and then choosing “Add Filter”, the dongle should appear in the provided list. You can also edit and remove the serial number from the Filter which will make it work for all Crazyradio dongles.
Installed software
  • Mercurial
  • TortoiseHG
  • pyusb, pygame and pyqt
  • Qt4 and QtDesigner
  • KiCad
  • gedit
  • SDCC 3.2
Projects
  • crazyflie-firmware
  • crazyflie-bootloader
  • crazyflie-pc-client
  • crazyradio-firmware
  • crazyradio-electronics
Development
HOW-TOs
Update all the projects
Run the Crazyflie PC client
Build the Crazyflie firmware
make CLOAD=1 DEBUG=0
projects/virtualmachine/index.1374840691.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
