Please note that direct downloads are hosted at MEGA, so it's limited to 6 downloads at a time. Using torrents are preferred.
OS : Xubuntu 13.04 HDD : ~8.8 GB (dynamically sized) RAM : 1 GB User: bitcraze Pass: crazyflie
NOTE: The USB filters in the 0.3 version of the VM specify a serial number for the radio dongle. This means the pre-configured filter cannot be used as is. Create your own filter by plugging in the radio and then choosing “Add Filter”, the dongle should appear in the provided list. You can also edit and remove the serial number from the Filter which will make it work for all Crazyradio dongles.
cd ~/projects/crazyflie-firmware hg pull && hg update -C 2013.4 cd ~/projects/crazyflie-pc-client hg pull && hg update -C 2013.4.2
cd ~/projects/crazyflie-firmware make CLOAD=1 DEBUG=0
