In order to easily get going with the development of Bitcraze projects we have pre-configured a virtual machine that can be imported into Oracle VirtualBox. It contains all the pre-requisites needed for development and usage of the projects at Bitcraze.
Please note that direct downloads are hosted at MEGA, so it's limited to 6 downloads at a time. Using torrents are preferred.
The latest available version of the VM is 0.6 and is created from scratch (i.e not updated from 0.5).
OS : Xubuntu 14.10 HDD : ~29 GB (dynamically sized) RAM : 1 GB User: bitcraze Pass: crazyflie
NOTE: The USB filters in the 0.3 version of the VM specify a serial number for the radio dongle. This means the pre-configured filter cannot be used as is. Create your own filter by plugging in the radio and then choosing “Add Filter”, the dongle should appear in the provided list. You can also edit and remove the serial number from the Filter which will make it work for all Crazyradio dongles.
There are also short-cuts on the desktop to easily run the Crazyflie PC client and also to update all the projects to the latest version available on GitHub.
If you would like to update to the latest version from GitHub for all the projects you can either use the short-cut on the desktop (Update all projects) or run the following command:
cd ~/projects/crazyflie-firmware make CLOAD=1 DEBUG=0
