To be able to debug the Crazyflie using JTAG you will need to solder the extra connector that is packaged with the Crazyflie on pins 1-10 on the EXT connector <insert image>. You will also need a JTAG debugger. The virtual machine is pre-configured to use the BusBlaster from DangerousPrototypes but can be set-up with any JTAG device that openOCD supports.
In order to start debugging do the followning:
and selecting openOCD server
and selecting crazyflie gdb
