projects:virtualmachine:jtag_debug
Prerequisites
To be able to debug the Crazyflie using JTAG you will need to solder the extra connector that is packaged with the Crazyflie on pins 1-10 on the EXT connector <insert image>. You will also need a JTAG debugger. The virtual machine is pre-configured to use the BusBlaster from DangerousPrototypes but can be set-up with any JTAG device that openOCD supports.
Debugging
In order to start debugging do the followning:
  • In the targets view double-click debug to build the firmware and then flash to flash it
  • Start the openOCD backend by pressing the small arrow on the External Tools button and selecting openOCD server
  • Start gdb by pressing the small arrow in the Debug button and selecting crazyflie gdb
  • Eclipse will now switch to the debugging interface and you are ready to debug
projects/virtualmachine/jtag_debug.1436970671.txt.gz · Last modified: 2016-10-10 11:36 (external edit)
