The Bootloader sits at the beginning of the flash memory 1) and handles the memory in pages:
+------------+ <- flashPages | | | | | | | | | | | | | | | | | | | | | Firmware | | | | | +------------+ <- flashStart | Bootloader | +------------+ <- Page 0
The size of the pages, the values flashStart and flashPages are comunicated by the protocol. For simplicity of the bootloader implementation this architecture is exposed to the procol
| Buffer page n | | Flash Page m |
| Buffer page 0 |----->| Flash |------>| Flash Page 0 |
v | v
| Bootloader control |
The procedure to flash is then to send the data to the buffer, and then order the bootloader to flash the buffer(s) in flash. All parameters like page size, number of flash page, number of buffer pages, are accessible via the protocol so that it is possible to change these physical values without changing the bootloader client.
All packets sent to the bootloader starts with “0xFF Target_number”, this kind of packets are called 'NULL Parcket' by CRTP and are ignored by the Crazyflie firmware. The target number has been introduced with Crazyflie 2 as it contains 2 bootloader. The mapping is as follow:
| Board | Target_number | MCU | Protocol version |
| Crazyflie 1 | 0xFF | STM32F103 | 0x00 |
| Crazyflie 2 | 0xFF | STM32F405 | 0x10 |
| 0xFE | nRF51822 | 0x10 |
The high nibble of the version aims at describing the board if board-specific change is required to the protocol (ie. GET_MAPPING that is specific to stm32f405).
All packets have the following format:
In the rest of this page commands and data are described.
| Command | Name | Note |
| 0x10 | GET_INFO | |
| 0x11 | SET_ADDRESS | Only implemented on Crazyflie version 0x00 |
| 0x12 | GET_MAPPING | Only implemented in version 0x10 target 0xFF |
| 0x14 | LOAD_BUFFER | |
| 0x15 | READ_BUFFER | |
| 0x18 | WRITE_FLASH | |
| 0x19 | FLASH_STATUS | |
| 0x1C | READ_FLASH |
| 0 | GET_INFO | 0x10 |
| 1-2 | pageSize | Size in byte of flash and buffer page |
| 3-4 | nBuffPage | Number of ram buffer page available |
| 5-6 | nFlashPage | Total number of flash page |
| 7-8 | flashStart | Start flash page of the firmware |
| 9-21 | cpuId | Legacy 12Bytes CPUID, shall be ignored |
| 22 | version | Version of the protocol |
This exchange requests the bootloader info. The content of this packet contains all information required to program the flash.
| 0 | SET_ADDRESS | 0x11 |
| 1-6 | address | 5 Bytes radio (ESB) address |
Sets the radio address. This allows to make sure no other computer will interfere with the flash process. It is not mandatory.
| 0 | GET_MAPPING | 0x12 |
| 1-.. | mapping | Erase page mapping of the flash, up to 27 bytes |
For all supported MCU except the STM32F405 when flashing one page the page is erased and then written with the new data.
The STM32F405 though has a very large flash memory (1M) and fairly large erase sector that have a different size. On this chip the bootloader is setup with 1024Bytes pages and when a page happens to be the first of a sector the full sector is erased. This command allows to request the size of the sectors.
The mapping field is encoded as a sequence of [Number of sector, Size of sector in page]. For example the STM32F405 has a mapping of [4, 16, 1, 64, 7, 128] because it contains 4 sector of 16KB, 1 of 64KB and 7 of 128KB. If this command where implemented in the STM32F103 the mapping would be [128, 1].
| 0 | LOAD_BUFFER | 0x14 |
| 1-2 | page | Buffer page to load into |
| 2-3 | Address | Address in the buffer page to load from |
| 3-27 | data | Data to load |
| 0 | READ_BUFFER | 0x15 |
| 1-2 | page | Buffer page to read |
| 2-3 | Address | Address in the buffer page to read from |
| 1-2 | page | Buffer page read |
| 2-3 | Address | Address in the buffer page read from |
| 3-27 | data | Data read |
| 0 | WRITE_BUFFER | 0x18 |
| 1-2 | bufferPage | Buffer page source |
| 3-4 | flashPage | Flash page destination |
| 5-6 | nPages | Number of page to program |
| 0 | WRITE_FLASH | 0x18 |
| 1 | done | At 0 if the operation failed, not 0 otherwise |
| 2 | Error | 0 if no error, otherwise contains error code |
The error code can be:
| Code | Meaning |
| 0 | No error |
| 1 | Addresses are outside of authorized boundaries |
| 2 | Flash erase failed |
| 3 | Flash programming failed |
| 0 | FLASH_STATUS | 0x19 |
This message aims at checking the latest flash operation in case where the WRITE_FLASH answer would be lost. The error code follows the same format as for WRITE_FLASH.
| 0 | READ_FLASH | 0x1C |
| 1-2 | page | Flash page to read |
| 2-3 | Address | Address in the flash page to read from |
| 1-2 | page | Flash page read |
| 2-3 | Address | Address in the flash page read from |
