Overview
How to get flying
  • Start up the application
  • Before you press connect make sure that the joystick is working as expected and that the thrust is zero. The joystick values should be visible in the flight data box under target.
  • Press Connect
  • Double-click the Crazyflie you want to connect to. There's one debug URI for UI testing so you should connect to the URI that begins with radio://80/XX/XX. The
  • One the handshake is done you can start flying the Crazyflie. Remember the most tricky part is the thrust so start out easy…
Once you have connected to the Crazyflie you can just use the Quick connect button next time you start the application.
Main UI
  2. Connect/disconnect and quick connect buttons as well as automatic connection
    • Connect: Will bring up a list of available Crazyflies to connect to
    • Quick connect: Will connect to the latest (successfully) connected Crazyflie
    • Auto-reconnect: If enabled the client will connect again if the connection is lost
Functionality
Connecting
  • List of Crazyflies: To connect either double-click, or select and then press Connect
  • Address: The shock burst address to scan for. If you didn't change this in the configuration, then leave the default of 0xE7E7E7E7
  • Scan: Re-scan for Crazyflies (not you're Crazyflie must be powered on to show up in the list)
  • Connect: Connect to the selected Crazyflie
  • Cancel: Go back
Firmware upgrade
  • Press “Browse” and select the binary you want to download (e.g. cflie.bin). For Crazyflie 2.0 a zip file containing firmware for both nRF51 and STM32F405 is possible to use.
  • Press “Program” and wait
Firmware configuration
Crazyflie 1.0 Crazyflie 2.0
Logging
Flight settings
Input devices
Creating new mappings
Selecting device
Tabs
Flightcontrol
  2. Roll/pitch trim can be set either in the UI or using the controller (if the correct buttons are mapped). This will offset the input to the Crazyflie for correcting imbalance and reducing drift.
  3. Advanced flight control settings are available if Advanced mode has been selected (settings are in %):
  4. Settings for flight decks, currently the LED-ring effect and headlights can be set (if the ring is attached)
  5. Target values sent from the client for controlling the Crazyflie
  6. Actual values logged from the Crazyflie
  7. Motor output on the Crazyflie
  8. Horizon indicator
Plotter
Parameters
Log blocks
  1. Fields
    • ID: Block id in Crazyflie
    • Name: Block name in client
Timestamp,pm.vbat
9103,3.74252200127
10103,3.74252200127
11103,3.74252200127
12103,3.74252200127
13103,3.74252200127
Console
Loco Positioning
Position estimate mode
Anchor identification mode
ZMQ backends
doc/crazyflie/client/pycfclient/index.1485435172.txt.gz · Last modified: 2017-01-26 13:52 by kristoffer
