Overview
How to get flying
  • Start up the application
  • Press Scan
  • When the handshake is done you can start flying the Crazyflie. Remember the most tricky part is the thrust so start out easy…
Main UI
    • Address: The chosen address (default 0xE7E7E7E7E7).
    • Auto Reconnect: Try to automatically reconnect when connection is lost.
  5. The selected and used input interface
Functionality
Connecting
  • List of Crazyflies: To connect either double-click, or select and then press Connect
  • Address: The shock burst address to scan for. If you didn't change this in the configuration, then leave the default of 0xE7E7E7E7
  • Scan: Re-scan for Crazyflies (note you're Crazyflie must be powered on to show up in the list)
  • Connect: Connect to the selected Crazyflie
  • Cancel: Go back
Firmware upgrade
  • Press “Program” and wait
Firmware configuration
Crazyflie 1.0 Crazyflie 2.0
Logging
Flight settings
Input devices
Creating new mappings
Selecting device
Tabs
Flightcontrol
  9. Horizon indicator
Plotter
Parameters
Log blocks
  1. Fields
    • ID: Block id in Crazyflie
    • Name: Block name in client
Timestamp,pm.vbat
9103,3.74252200127
10103,3.74252200127
11103,3.74252200127
12103,3.74252200127
13103,3.74252200127
Console
Loco Positioning
Position estimate mode
Anchor identification mode
ZMQ backends
doc/crazyflie/client/pycfclient/index.1492525004.txt.gz · Last modified: 2017-04-18 16:16 by tobias
