Overview
How to get flying
  • Start up the application
  • Press Scan
  • When the handshake is done you can start flying the Crazyflie. Remember the most tricky part is the thrust so start out easy…
Main UI
    • Address: The address to scan for. If you didn't change this in the configuration, then leave the default of 0xE7E7E7E7E7
    • Auto Reconnect: Try to automatically reconnect when connection is lost.
  5. The selected and used input interface
Functionality
Firmware upgrade
  • For Crazyflie 2.0 hold the button for about 3 seconds when turning it on until the blue LED M2 starts to blink to get into bootloader mode. If a wrong nRF51 firmware has been flashed you might have to start from an un-powered state. Then hold the button and connect power.
  • Press “Program” and wait
Firmware configuration
  • Radio channel Can be set to anything between 0 and 125, correspond to a frequency from 2400MHz to 2525MHz. In most countries channel 0 to 80 is OK to use but this should be checked with you local regulations. If using 2M datarate, the copter channels should be 2 apart (2MHz).
Crazyflie 1.0 Crazyflie 2.0
Logging
Flight settings
Input devices
Creating new mappings
Selecting device
Tabs
Flightcontrol
  9. Horizon indicator
Plotter
Parameters
Log blocks
  1. Fields
    • ID: Block id in Crazyflie
    • Name: Block name in client
Timestamp,pm.vbat
9103,3.74252200127
10103,3.74252200127
11103,3.74252200127
12103,3.74252200127
13103,3.74252200127
Console
Loco Positioning
Position estimate mode
Anchor identification mode
ZMQ backends
doc/crazyflie/client/pycfclient/index.1492525591.txt.gz · Last modified: 2017-04-18 16:26 by tobias
