doc:lps:tdoa3:protocol
TDoA Anchor protocol V3 (experimental)
NOTE
This is work in progress. The specifications on this page may change at any time without backwards compatibility.
System architecture
The protocol is designed to be used with a large number of anchors covering a big area. Each anchor has a limited reach and covers only a small area, but by adding more anchors the system will be able to cover an (virtually) unlimited area. At any point in the covered area, 5-10 anchors should be within range of a Tag.
Packet scheduling
Packet format
  • Header
    • type: 0x30
  • Remote anchor data
Tag implementation
A TDoA tag is simply an UWB sniffer. A sniffer can use the data in the packets together with the packet receive timestamps to calculate its position.
doc/lps/tdoa3/protocol.1525265040.txt.gz · Last modified: 2018-05-02 14:44 by kristoffer
