misc:hacks:taranisandroid
Using a Taranis 9x (Pro) RC transmitter with the Crazyflie Android client
If you already own a Taranis 9x (Pro) RC transmitter and want to use it as a controller, it can be configured to work with the Crazyflie Android client.
Fortunately the transmitter is able to act as an USB Joystick (see https://github.com/opentx/opentx/wiki/OpenTX-USB-Joystick), but first you need to create a new model for this configuration:
  • you can turn off both internal and external TX modules
  • you need to configure the thrust input (Weight 50% and Offset 50%)
    • otherwise you can not use the full travel of the axis assigned to thrust
  • Servos menu
    • invert Thrust (CH1)
    • invert Eleron (CH3)
misc/hacks/taranisandroid.1437083106.txt.gz · Last modified: 2015-07-16 23:45 by fred
