https://www.bitcraze.io/docs/crazyflie-firmware/master/openocd_gdb_debugging/
One of the key components of getting really serious about developing on the crazyflie, is to dive into the C-based firmware. If you really want to do some major changes to the intrinsic of the code, it is essential to have proper tools to be able to debug the code (place breakpoints, read real-time values ect…). On this page, we will put a few examples how to do this with IDE's and different environments.
This page requires our debug adapter! See this page: Debug adapter
sudo apt-get update sudo apt-get install gdb sudo apt-get install openocd
Then install java:
sudo apt install default-jre
Then install eclipse itself: Go to their download page: eclipse 20 and then go into you download folder and unzip the file.
and start up eclipse:
check the following settings: OpenOCD setup → Config options:
-f interface/stlink-v2.cfg -f target/stm32f4x.cfg -c init -c targets
GDB Client Setup:
set mem inaccessible-by-default off
Make sure that your cf2.elf is the same as the one you uploaded to the crazyflie.
Install gdb and openocd
brew install gdb brew install open-ocd
Install java JDK java download
Download eclipse eclipse download
Run eclipse and choose work folder
