Bosch Sensortec expansion deck V2 schematic
SENSORS = bosch
static uint8_t gyroPrimInUse = SENSORS_BMI055; static uint8_t accelPrimInUse = SENSORS_BMI055;
Now you are ready to make the firmware and flash it on your crazyflie.
