projects:crazyflie2:expansionboards:index
Expansion decks
Mechanical architecture
Orientation
One expansion board on top
One expansion board on top, one on bottom
Two expansion board on top
Expansion port pinout
Expansion board detection
Deck info
VID PID ID Name Weight Consumption Mount location Details page Schematic
0xBC 0x01 bcLedRing LED-ring 3.3g 0 - 700mA Below link link
0xBC 0x02 bcQi Qi charger 5g N/A Below link link
0xBC 0x04 bcBuzzer Buzzer 1.8g 10mA Below/Above link link
0xBC 0x05 bcBigQuad Big quad 3.8g N/A Below/Above link link
0xBC 0x06 bcDWM UWB LPS 3.3g 160mA Below/Above link link
0xBC 0x08 bcUSD Micro-SD 1.7g ~30mA Below/Above link link
0xBC 0x09 bcZRanger Z-Ranger 1.3g ~30mA Below link link
0xBC 0x0A bcFlow Flow 1.6g ~40mA Below TBD TBD
Deck pin allocation
UART1 I2C STM32 IO UART2 SPI nRF51 IO
Name RX1 TX1 SDA SCL IO1 IO2 IO3 IO4 TX2 RX2 CLK MOSI MISO NIO1 NIO2 PWR
bcLedRing PWM PWM VCOM
bcQi GHG N/A
bcGPS X X (PP)S (RST) (X) (X) (VBAT) VCOM
bcUSD (CS) (CS) (CS) CS X X X VCC
bcDWM IRQ RST CS (IRQ) (RST) X X X VCOM
bcBigQuad (X) (X) (X) (X) X X (X) X X (X) (X) (X) N/A
bcBuzzer PWM PWM N/A
bcESP (X) X X N/A
bcZRanger X X (X) VCC
bcFlow X X (X) X X X X VCC
projects/crazyflie2/expansionboards/index.1494512909.txt.gz · Last modified: 2017-05-11 16:28 by arnaud
