The Z-ranger deck will be automatically detected when it is mounted. By default the range is available on the log variable “range.zrange” and is used instead of the pressure by internal algorithms.
The best way to use the Z-Ranger deck is to enable the Height-hold mode in the client. This requires at least client and firmware 2017.04 so make sure to update your Crazyflie.
The Kalman filter is a sensor fusion algorithm that is still experimental. You can try it by recompiling the Crazyflie firmware.
To enable altitude control using the Z-ranger with the kalman filter, the Crazyflie firmware has to be recompiled with the following config.mk:
ESTIMATOR=kalman CFLAGS += -DUPDATE_KALMAN_WITH_RANGING -DKALMAN_DECOUPLE_XY
The sensor can measure distances up to 2 meters but often fails at distances above 1.5m. In case of unreliable readings the Crazyflie 2.0 will slowly drift. If that happens bring it down to the detection range.
