The Crazyflie 2.0 is a solderless development kit that needs to be assembled before it's used. Please read through all the instructions on this page before assembly and make sure to follow them.
What's in the packet
  • 5 x CW propellers
  • 5 x CCW propellers
  • 5 x Motor mounts
  • 1 x LiPo battery (240mAh)
  • 5 x Coreless DC motors
Needed for assembly
Before you start
  • Unpack the Crazyflie 2.0 control board and connect it using a uUSB cable.
  • The M1 LED will now blink 5 times fast to indicate the result of the self tests. If the LED blinks green, the tests are ok. If the LED blinks red, the tests has failed.
  • Now connect a client to the Crazyflie. If the connection is successful then the Crazyflie 2.0 is ready for assembly. But if these tests do not pass, then contact the retailer where you purchased the unit.
Assembly steps
3. Slide the motor mounts onto the 4 wings of the Crazyflie 2.0, it doesn't matter what motor you attach where. Make sure that the wing goes all the way into the motor mount to fasten it firmly.
4. Connect the motor connectors to the Crazyflie 2.0
5. Attach the propellers to the motors. For motor M1/M3 you should use CCW propellers and for M2/M4 you should use CW propellers. If you don't know which is which, then have a look at the images below.
6. Ready!
Video
Motors and propellers
projects/crazyflie2/userguide/assembly.1411494931.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
