The Crazyflie 2.0 is a solderless development kit that needs to be assembled before it's used. Please read through all the instructions on this page before assembly and make sure to follow them.
What's in the packet
  • 5 x CW propellers
  • 5 x CCW propellers
  • 5 x Motor mounts
  • 1 x LiPo battery (240mAh)
  • 5 x Coreless DC motors
Needed for assembly
Before you start
  • Unpack the Crazyflie 2.0 control board and connect it using a uUSB cable.
  • The M1 LED will now blink 5 times fast to indicate the result of the self tests. If the LED blinks green, the tests are ok. If the LED blinks red, the tests has failed.
  • Now connect a client to the Crazyflie. If the connection is successful then the Crazyflie 2.0 is ready for assembly. But if these tests do not pass, then contact the retailer where you purchased the unit.
Assembly steps
4. Attach the propellers to the motors according to this image. Click the images for a larger version if needed.
5. Connect the battery and place the battery holder on top of it to keep the battery in place.
6. Ready!
Video
Propeller placement
projects/crazyflie2/userguide/assembly.1411561133.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
