The Crazyflie 2.0 is a solderless development kit that needs to be assembled before it's used. Please read through all the instructions on this page before assembly and make sure to follow them. An assembly video is also available.
4. Attach the propellers to the motors according to this image. Make sure that the propellers bend upwards like the image below, otherwise they are turned upside-down.
5. Connect the battery and place the battery holder on top of it to keep the battery in place.
6. Ready!
