Implemented link drivers:
| Link | |
Current port allocation:
| Port | Target | Used for |
To ping Crazyflie:
| Port | Channel | Function |
| 5 | 2 | Log data access |
| TOC CRC and count | 0 | 0x01 Request the TOC CRC and item count |
| 1 | ||
Computer Crazyflie
Get TOC CRC32 --->
<--- TOC CRC32
[Compare CRC]
Computer Crazyflie
Request for TOC item 0 --->
<--- First TOC element
Request for TOC item 1 --->
<--- Requested TOC element
Request for TOC item N-1 --->
where N is Number of
total variables in TOC
<--- Last TOC element
[optional]
Request for TOC item N --->
(or any higher)
[Fetch complete]
| 1 | Desired block id | |
| 2-31 | Variables to log | |
| 1 | Block ID | |
| 1 | Block ID | |
| Start a log block | 0 | 0x03 to identify the command for enabling logging data from an existing block |
| 1 | Block ID | |
| Stop a log block | 0 | 0x04 to identify the command for disabling logging data from an existing block |
| 1 | Block ID | |
| Reset log | 0 | 0x05 to identify the command to reset log. All blocks are stopped and deleted |
| Byte | Description |
Log Type represents type of value sent in packet. Logged value is converted to this type before storing into log packet. Upper bytes will be discarded if Log Type is integer and value does not fit.
| Log Type | Description |
| 1 | uint8_t |
| 2 | uint16_t |
| 3 | uint32_t |
| 4 | int8_t |
| 5 | int16_t |
| 6 | int32_t |
| 7 | float32 |
| 8 | float16 |
| 0 | Variable in TOC |
TOC variable request (Storage type is ignored):
7 6 5 4 3 2 1 0 +---+---+---+---+---+---+---+---+ | Storage type | Log type | +---+---+---+---+---+---+---+---+ | Variable ID | +---+---+---+---+---+---+---+---+
Arbitrary memory address request:
7 6 5 4 3 2 1 0 +---+---+---+---+---+---+---+---+ | Storage type | Log type | +---+---+---+---+---+---+---+---+ | 0xff | +---+---+---+---+---+---+---+---+ | Mem Address 0 | +---+---+---+---+---+---+---+---+ | Mem Address 1 | +---+---+---+---+---+---+---+---+ | Mem Address 2 | +---+---+---+---+---+---+---+---+ | Mem Address 3 | +---+---+---+---+---+---+---+---+
| Error | Description |
| 0 | No error |
| ENOENT (2) | Block or variable not found |
| E2BIG (7) | Log block is too long |
| ENOEXEC (8) | unknown command received |
| ENOMEM (12) | No memory to allocate Log Block or Log Item |
Adding a new log block with id 0x0a with variable 0x55 type uint32_t and variable 0x66 type float32 to the settings:
Computer Crazyflie
Add log block --->
<--- Log block added ok
[DONE]
Packet structure:
Computer -> CF : 0x[5,1] 0x00 0x0a 0x03 0x55 0x07 0x66
CF -> Computer : 0x[5,1] 0x00 0x0a 0x00
Deleting an existing log block 0x55 from the settings:
Computer Crazyflie
Delete log packet --->
<--- Log packet deleted ok
[DONE]
Packet structure:
Adding a log block 0xbb at 100ms interval logging variable ID 0x55 of type uint16: Computer -> CF : 0x[5,1] 0x00 0xbb 0x02 0x55 // create logging block CF -> Computer : 0x[5,1] 0x00 0x55 0x00 Computer -> CF : 0x[5,1] 0x00 0xbb 0x0A // start sending block with 100ms interval Receiving a log block 0xbb 1300ms logging variable (value 0xBABE): CF -> Computer : 0x[5,2] 0xBB 0xA3 0xA2 0xA1 0xBA 0xBE
| Port | Function |
| (0,9,0) | TOC access |
| (0,9,1) | Parameter read |
| (0,9,2) | Parameter write |
| 0 | | | | |
| 1 | | | | |
| 3 | Num. Param | CRC32 |
Bytes 1 1 4
| 3:15:0 | Echo (profiling) |
| 3:15:2 | Sink (profiling) |
| 3:15:3 | NULL packet |
