Implemented link drivers:
| Link | |
Current port allocation:
| Port | Target | Used for |
To ping Crazyflie:
| Port | Channel | Function |
| 5 | 2 | Log data access |
| TOC item | 0 | 0x00 (CMD_GET_ITEM) to identify the command |
| TOC CRC and count | 0 | 0x01 (CMD_GET_INFO) Request the TOC CRC and item count |
| 1 | ||
| TOC CRC and count | 0 | 0x01 (CMD_GET_INFO) to identify the command |
Computer Crazyflie
Get TOC CRC32 --->
<--- TOC CRC32
[Compare CRC]
Computer Crazyflie
Request for TOC item 0 --->
<--- First TOC element
Request for TOC item 1 --->
<--- Requested TOC element
Request for TOC item N-1 --->
where N is Number of
total variables in TOC
<--- Last TOC element
[optional]
Request for TOC item N --->
(or any higher)
[Fetch complete]
| Create a new log block | 0 | 0x00 (CONTROL_CREATE_BLOCK) for identifying the command to add a logging block |
| 1 | Desired block id | |
| 2-31 | Variables to log | |
| Append to existing log block | 0 | 0x01 (CONTROL_APPEND_BLOCK) for identifying the command to append logging variables to an existing block |
| 1 | Block ID | |
| Delete a log block | 0 | 0x02 (CONTROL_DELETE_BLOCK) to identify the command for delete an existing block |
| 1 | Block ID | |
| Start a log block | 0 | 0x03 (CONTROL_START_BLOCK) to identify the command for enabling logging data from an existing block |
| 1 | Block ID | |
| Stop a log block | 0 | 0x04 (CONTROL_STOP_BLOCK) to identify the command for disabling logging data from an existing block |
| 1 | Block ID | |
| Reset log | 0 | 0x05 (CONTROL_RESET) to identify the command to reset log. All blocks are stopped and deleted |
| Byte | Description |
| 1 | The ID of the log block that the command operated on (undefined for Reset log) |
Log Type represents type of value sent in packet. Logged value is converted to this type before storing into log packet. Upper bytes will be discarded if Log Type is integer and value does not fit.
| Log Type | Description |
| 1 | uint8_t |
| 2 | uint16_t |
| 3 | uint32_t |
| 4 | int8_t |
| 5 | int16_t |
| 6 | int32_t |
| 7 | float32 |
| 8 | float16 |
| 0 | Variable in TOC |
TOC variable request (Storage type is ignored, it is taken from Crazyflie internal TOC):
7 6 5 4 3 2 1 0 +---+---+---+---+---+---+---+---+ | Storage type | Log type | +---+---+---+---+---+---+---+---+ | Variable ID | +---+---+---+---+---+---+---+---+
Arbitrary memory address request:
7 6 5 4 3 2 1 0 +---+---+---+---+---+---+---+---+ | Storage type | Log type | +---+---+---+---+---+---+---+---+ | 0xff | +---+---+---+---+---+---+---+---+ | Mem Address 0 | +---+---+---+---+---+---+---+---+ | Mem Address 1 | +---+---+---+---+---+---+---+---+ | Mem Address 2 | +---+---+---+---+---+---+---+---+ | Mem Address 3 | +---+---+---+---+---+---+---+---+
| Error | Description |
| 0 | No error |
| ENOENT (2) | Block or variable not found |
| E2BIG (7) | Log block is too long |
| ENOEXEC (8) | Unknown command received |
| ENOMEM (12) | No memory to allocate Log Block or Log Item |
Adding a new log block with id 0x0a with variable 0x55 type uint32_t and variable 0x66 type float32 to the settings:
Computer Crazyflie
Add log block --->
<--- Log block added ok
[DONE]
Packet structure:
Computer -> CF : 0x[5,1] 0x00 0x0a 0x03 0x55 0x07 0x66
CF -> Computer : 0x[5,1] 0x00 0x0a 0x00
Deleting an existing log block 0x55 from the settings:
Computer Crazyflie
Delete log packet --->
<--- Log packet deleted ok
[DONE]
Packet structure:
Logging data is sent back to the copter as raw data with only the block id. This means that the lookup of what data is for what variable has to be done on the computer side. Log block header contains 3 byte timestamp, its value is number of milliseconds from Crazyflie system start (it will wrap around in about 5 hours). All values are sent in little endian format.
| 0 | Block ID |
| 1-3 | Block send time timestamp in ms, LSB first |
| 4-31 | Logged variable values, LSB first |
Adding a log block 0xbb at 100ms interval logging variable ID 0x55 of type uint16: Computer -> CF : 0x[5,1] 0x00 0xbb 0x02 0x55 // create logging block CF -> Computer : 0x[5,1] 0x00 0x55 0x00 // OK Computer -> CF : 0x[5,1] 0x00 0xbb 0x0A // start sending block with 100ms interval CF -> Computer : 0x[5,1] 0x00 0x55 0x00 // OK Receiving a log block 0xbb with timestamp 130.532s (0x1FDE4 ms), logging uint16 variable with value 0xBABE: CF -> Computer : 0x[5,2] 0xBB 0xE4 0xDF 0x01 0xBE 0xBA
| Port | Function |
| (0,9,0) | TOC access |
| (0,9,1) | Parameter read |
| (0,9,2) | Parameter write |
| 0 | | | | |
| 1 | | | | |
| 3 | Num. Param | CRC32 |
Bytes 1 1 4
| 3:15:0 | Echo (profiling) |
| 3:15:2 | Sink (profiling) |
| 3:15:3 | NULL packet |
