projects:crazyflie:upgrading:index
Upgrading/flashing the Crazyflie Nano (1.0)
There are currently two ways to flash the Crazyflie Nano
Upgrade/flash using the Crazyradio or Crazyradio PA
The Crazyflie Nano contains a bootloader with which it can be updated over the air (OTA). Either using the cfclient or from command line.
Upgrade/flash using a JTAG degugger/flasher
This is mainly for development and requires a JTAG debugger with ARM Cortex 10-pin interface.
Upgrade/flash using the Crazyflie Android client with the Crazyradio (PA)
projects/crazyflie/upgrading/index.txt · Last modified: 2021-06-24 14:53 by kimberly
