This short guide shows some basic usage of the Crazyflie. It's intended as an introduction that's useful before flying the first times.
Currently the only input controller supported is the Playstation 3 gamepad. For more information see the [link to UI page]. The Crazyflie has 4 different controls: Pitch, roll, yaw and thrust.
Changing the pitch and roll will make the quadcopter change orientation and thus change the direction that it's moving in. Tiling the quadcopter forward will make it go farward and the same for every other direction.
The Crazyflie is contructed without a separate frame, it uses the PCB as a frame and simply attaches four motors to it. This means that the weight of the platform is very low and on most impacts it simply bounces of objects. If you are unlucky either propellers or motors might break when crashing. If so have a look at our [link to repair page] for some basic repairs.
When USB is connected:
When USB is not connected:
