Currently the only input controller supported is the Playstation 3 gamepad. For more information see the [link to UI page]. The Crazyflie has 4 different controls: Pitch, roll, yaw and thrust.
The Crazyflie is contructed without a separate frame, it uses the PCB as a frame and simply attaches four motors to it. This means that the weight of the platform is very low and on most impacts it simply bounces of objects. If you are unlucky either propellers or motors might break when crashing. If so have a look at our [link to repair page] for some basic repairs.
'make sure you have the correct channel set')For more tips on flying take a look at the [link to tips and tricks page].
When USB is connected:
When USB is not connected:
